Disables sending SNMP trap when saving or changing the switch configuration.
configuration | Sends SNMP trap for switch configuration. |
save | Disables SNMP trap when switch configuration is saved (default is disabled). |
change | Disables SNMP trap when switch configuration is changed (default is disabled). |
The default is that SNMP traps are disabled for switch configuration changes/saves.
The following example disables SNMP traps for switch configuration saves:
disable snmp traps configuration save
This command was first available in ExtremeXOS 22.1.
This command is available on all Universal switches supported in this document..
